If you want to have some styles in the drop down you actually need to do one more thing. You must create the styles that you want as children to the stylesheet that you've attached to the richtext editor. This means going to the Settings section and right click the stylesheet you attached to the editor. Now you can create all of the styles tht you need in the drop down.
[4.7] CSS in Richtext editor
I have made a css file and included that in "Developer" - "Datatype" - "Richtext editor". But the styles dont appear in the dropdown?
Hi Niels
I hope it makes sense to you Niels.
/Kim A
Hi Kim
How stupid of me.... that was also what I have done before :(
/Niels
No problem :)
The main stylesheet that you create is for the styling inside of the richtext editor, but you probably already know this :)
By the way, if you can mark this post as solved it would be great.
/Kim A
How to mark it solved?
Under each answer that's not your own, there's a small green tich that you can click to select the correct solution for your answer.
/Kim A
Hi Kim,
Thanks for sharing your solution. Much appreciated.
Regrads,
Sravani
You're welcome Sravani. I'm glad that you can use my answers :)
/Kim A
